Old 07-01-2020, 10:50 AM   #1
PingaPete
Drives: 2003 Vitz
fuel sender units???
hello guys, just wondering if the sender units for a Toyota echo are different to the ones used in the vitz. ive recently swapped from a digital cluster to a rs analog one and the fuel gauge is showing a error by flashing all bars full then will stop flashing and show empty. so what im thinking is the senders need to be different???
any help and part numbers will be appreciated
PingaPete is offline   Reply With Quote
Old 07-01-2020, 12:06 PM   #2
alanwagen
OEM
Very specific requirements. You should always go with OEM on this.
Old 07-02-2020, 01:57 AM   #3
PingaPete
Drives: 2003 Vitz
no im not sure if the fuel senders are different
Old 07-02-2020, 06:22 AM   #4
stidnam
Drives: Starlet
The JDM RS shares the same sender unit as our ADM Echo. However, the sender unit for our ADM Echo that comes with the digital dash is different. Hope that makes sense.
So did your Echo originally have a digital dash?
stidnam is offline   Reply With Quote
Old 07-02-2020, 07:16 AM   #5
PingaPete
Drives: 2003 Vitz
Yes I converted it over to a analog dash. So I believe the sender unit is different as I went to Toyota today and asked for part numbers for them. One said fuel sender (W/digital meter /with tacho/KM/H. So I’m going to order it and hopefully it fixes the issue
Old 07-02-2020, 07:29 AM   #6
stidnam
Drives: Starlet
Gotcha. I just looked up the parts catalog and it's that digital one that's shared across the models. Looks like part# 83320-52061
Fuel pump, sender, seal, wiring, and cluster mavrick DIY / Maintenance / Service 5 07-22-2019 05:34 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
