Old 07-02-2020, 10:10 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Rotors and Pads Replaced
Been meaning to do this for a while. I did it mainly for cosmetic reasons. Rotors had the usual rust scale on the vanes. The brakes were working fine, with a tiny bit of shaking while high speed braking (over 140 km/h). I know, I know but the car just wants to go fast. Not my fault, the car's.
I actually reused the OE (I think) pads, which were replaced not that long ago. They were perfectly smooth, with, I'd say, 80 - 90% lining remaining. The aftermarket ones were chamfered on the ends and don't seem to have as much contact surface.
The job was uneventful with the exception of the upper driver's side caliper bracket bolt. That was a beeotch. The lower strut bolt makes it hard to use an impact gun. So, a 17mm wrench and BFH was used. Probably took 5 minutes of solid hammering to loosen that up. Needless to say, every bolt got a nice application of anti-seize, as did the hub/wheel contact surfaces. All four caliper pins operated smoothly but still got a cleaning and repack with silicone brake lube.
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
New front brake pads and rotors NEexpat DIY / Maintenance / Service 7 09-10-2013 10:43 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
New Pads and Rotors after 18K Miles??? dadi_oh DIY / Maintenance / Service 19 09-06-2007 08:52 AM
