Old 07-16-2020, 08:26 PM   #1
dandoyzki
Drives: Blue Vios 1nzfe bagged
Lightbulb Maxspeedingrods H-BEAM Rods
Hello,
I am planning to replace my stock connecting rods with a forged one.
bumped with molnar and maxspeedingrods.
Maxspeeding rods is cheap but looks promising, what do you think with it?
Someone already used it for a forged 1nz build?
Thanks!!!
dandoyzki is offline   Reply With Quote
Old 07-20-2020, 10:56 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by dandoyzki View Post
Hello,
Thanks!!!
Doesn't Maxpeedingrods produce a budget line of products? I don't know about their rods, but if you going to the trouble and expense of tearing an engine apart and rebuilding it, I'd be inclined to go for a reputable brand and a company that focuses solely on one type of product, such as Crower, Molnar (as you mentioned), Carrillo or even MWR (Monkey Wrench Racing). I'd prefer to spend a bit more to ensure quality.
EDIT: I found this article. I didn't read all of it, but it actually looks like they might be decent. Someone confirmed that they used ARP rod bolts.
https://www.mgexp.com/forum/mg-motor...-rods.2265921/
Old 07-23-2020, 09:22 PM   #3
Personally, I wouldn't "cheap" out on engine components with going with a more wallet friendly brand. The last thing you'd want to happen is having your engine fail on you.
connecting, forged, rods
Dimmed high beam as DRL? Ot_tO Cosmetic Modifications (Exterior/Interior) 5 08-21-2012 12:34 AM
DRL: Low beam or -lamps - or not? Ot_tO General Yaris / Vitz Discussion 10 07-27-2012 07:11 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Hi beam works - Lo beam dosen't!!!!! fuji DIY / Maintenance / Service 7 05-25-2009 04:33 AM
High Beam Mod stran DIY / Maintenance / Service 1 11-13-2008 11:06 AM
