Old 07-19-2020, 12:19 PM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
1st into 2nd
I've noticed on my 5spd that sometimes, but not all the time, when shifting from 1st to 2nd gear, the shifter sometimes wants to pop out of 1st gear when I clutch in and initiate the shift. It won't pop out of gear on its own, but only sometimes (not always) when I hands on initiate the shift. Anyone know what this could possibly be? Anything to worry about? Is it normal?
Thanks in advance.
Old 07-23-2020, 06:03 PM   #2
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
manual transmission cars are rare
talk to Kalispel II on this forum
Old 07-23-2020, 09:08 PM   #3
Never had a gear pop out by itself on any car I've owned. Definitely not normal. Could be a number of things that are starting to fail, from bushings to forks.
Old 07-27-2020, 11:59 AM   #4
Leegamer
Leegamer's Avatar
Agreed. I have never had this issue with my 08. I would start with checking the transmission fluid. I don't believe the manual tranny has a dipstick though (I could be wrong, haven't looked for a while) so you'd have to check the level via the fill plug.
I'm a hermit named Lee
Old 08-08-2020, 12:11 PM   #5
ex-x-fire
I'd check motor mounts too.
Old 08-10-2020, 10:37 PM   #6
bentjazz
Taking it into Toyota Service Center on Friday. If there's anything wrong, I'll update. Thanks for all the replies, fellow Yarisworlders.
Old 08-12-2020, 02:10 PM   #7
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Mine's a manual and I haven't experienced this either. Hoping for good news for you from the service center...
On Instagram
On Wheelwell
Old 08-14-2020, 10:36 AM   #8
bentjazz
Hi Yarisworlders. Went to the service center today and the axle is leaking, and he showed me where the gear oil is leaking. So, they're going to fix it today and I'll get it back later. I'm hoping that this was the source of the problem I was experiencing due to lower levels of gear oil caused by the axle leaking. One question I have is could I have in any way caused the axle seal to leak? Thanks in advance.
problem of gearing, 1st and 2nd gear, Yaris 2008, 1.3 VVTi 64 kw cylaptor DIY / Maintenance / Service 18 03-05-2019 10:40 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
When to go from 1st to 2nd to 3rd and so... yaristhebest Fuel Economy Forum 30 01-15-2013 05:32 AM
My 1st and 2nd Auto-X'S SLIK4 Tracking, Racing, Auto-X Forum 6 06-08-2011 08:45 AM
The First Annual Kevin Duckworth Scholarship Car Show kingpincaraudio Northwest 5 06-24-2009 01:32 PM
