Old 07-20-2020, 08:03 PM   #1
Perkele
Kuljettaja
Drives: 2013 Yaris LE
My oil was overfilled. How much is too much?
I checked my dipstick after an oil change on my Yaris and the oil is slightly overfilled (or so I think its slightly). I'm wondering if I have to get the excess oil sucked out or just keep driving. So far I have driven my Yaris 300 Ks like this without any noticeable issues.
Perkele is offline   Reply With Quote
Old 07-20-2020, 09:20 PM   #2
bronsin
bronsin's Avatar
It appears to me it’s Wayover full. I would bring the car back where the work was done and show them the dipstick. Tell them you want it fixed.
My 09 Yaris blue and oil pressure sensor from an overfill. When the oil light came on I stopped and had the car flat headed to Toyota. $300. I don’t like to think what would have happened if my wife was driving.
Old 07-20-2020, 10:44 PM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I'm pretty sure the oil in the 1NZ engine is contained in a sump separate from the crankshaft counterweights, so it's unlikely to foam the oil, which is often the problem with oil overfills. Foamy oil provides pretty poor lubrication. As much as that looks really overfilled, it is likely only a liter or so over. From the bottom mark to full mark is probably not much more than a liter itself. I would still take it back and have them drain a bit out. You may as well since you already paid it have it done.
Old 07-20-2020, 11:42 PM   #4
Perkele
Kuljettaja
Will definitely bring it back to them to drain out the excess oil. This will be the last time I bring my Yaris into the Toyota dealer for an oil change. I will change oil myself and as inconvenient as it may be, it's worth it because if they overfill by such a significant amount I have trouble trusting them to do it again. Such a careless, sloppy mistake.
Old 07-21-2020, 07:25 AM   #5
ex-x-fire
Yeah, get that taken care of. I write the oil capacity on the engine cover so I don't have to guess.
Old 07-21-2020, 07:55 AM   #6
06YarisRS
Yes, I get your frustration. Certainly, you'd expect to have a Toyota dealership do the job correctly. Years ago I owned a 5.0 Mustang LX. The car had a double hump oil pan with two drains. It wasn't a dealer oil change but they only drained one side of the pan and then refilled with the factory spec amount. I was significantly overfilled as a result. Obviously, they just dumped the oil in and didn't even bother checking the dipstick, dipsticks!
Doing your own oil changes is the best way to ensure that you get the job done properly. Plus, it's rewarding and saves a lot of money, especially since you can grab a high quality, inexpensive jug of synthetic oil and a filter from any Walmart.
Old 07-21-2020, 12:09 PM   #7
Leegamer
Leegamer's Avatar
Wow, 2 drains? I have never owned a car like that or even considered that possibility. It just goes to show you though that places that specialize in something as trivial as an oil change can screw it up.
I guess the benefit is that if they screw it up and it causes a catastrophic failure they can be held liable (though probably difficult to prove). If I screw up it's all on me, but I'll still keep changing my own oil because I'm cheap. Lol.
I'm a hermit named Lee
Old 07-21-2020, 09:36 PM   #8
ex-x-fire
The OP might want to invest in an oil extractor and do the oil changes themselves. The price for them lately is very reasonable.
Old 07-21-2020, 10:30 PM   #9
06YarisRS
The 5.0 had to sit low in the chassis and the oil pan straddled the front cross member, thus the need for a double hump pan. I think I had that oil change done at Canadian Tire. It was likely farmed out to a 17 yr old. Lol. I think that's about the time I started doing my own changes. Haha. As for being cheap...I am too. lol. You get better oil, better filter, it costs about 1/2 the price and you know it's done right when you DIY.
Old 07-21-2020, 10:36 PM   #10
06YarisRS
Nice! A great investment. I bought one of the cheap eBay 12v extractors for about $12.00. Super convenient and connects to the battery with battery clamps. It has a very thin draw line, so can get to the bottom of the oil sump and trans fluid sump. Love it!
Old 07-22-2020, 03:33 PM   #11
komichal
The oil extractors sucks. Not only literally.
Losening one bolt is faster, gets more old oil out, gets out any debris sitting in the bottom of the oil pan. You have to remove oil filter anyway.
It is a bit dirty job, yes. But nothing that a piece of plastic underneath the car (plus gloves) cannot solve.
Old 07-22-2020, 08:48 PM   #12
06YarisRS
Agree that slipping under the car and draining out a bit is the best approach. My extractor does come in very handy though for quick fluid removal without the need to jack and jackstand the car. I would never do an oil change this way as as you mention, the filter has to be changed.
Old 07-22-2020, 09:07 PM   #13
ex-x-fire
Nothing wrong with extracting oil and what is this debris inside of engines? I use dino oil and never have any issues.
If you want to get more oil when draining through the plug, you have to raise the the left side of the car, you might get an extra cup or two of oil out.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
