Old 07-30-2020, 08:45 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Alignment and a little exhaust work
Had the car in to a local shop for an alignment after my coilover install. For such a small town, this outfit has a really high tech Hunter alignment system. It was the first time I've actually seen an alignment done. Very interesting. I asked about the toe at the right rear and the tech said it's so minor that I shouldn't worry about it. I'm guessing if I want to bring it back in, I might need a shim or something since there's no adjustment at the back - at least that's my understanding. Open to the opinions of those familiar with the rear suspension. While I was there, I got all 4 tires balanced.
I also had them remove a clamp on my exhaust and weld the connection. It basically gained me about an extra 1" of clearance. I will likely be dropping the car a bit in the near future, so they know I might be back for a small camber and toe tweak.
I was impressed when I was only charged $120.00 for all the work.
Old 08-03-2020, 10:26 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I get the alignment shim disc and minimize that variance but thats me. You probably never feel that unless you drive hard
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-04-2020, 07:21 AM   #3
ex-x-fire
Yeah, as shim at the RR will help put both of those readings closer to spec.
Old 08-04-2020, 11:30 PM   #4
06YarisRS
Thanks gentlemen! I will look into a shim to get the rear right wheel back within spec.
Old 08-05-2020, 07:05 AM   #5
ex-x-fire
You have the read out, so you know (or can figure out) how to put the shim in. Watch some youtube videos on installing them. It'll save you some money by installing it yourself.
Old 08-05-2020, 09:35 PM   #6
06YarisRS
For sure. I assume shims are generic? Will investigate. Thanks!
Old 08-06-2020, 07:15 AM   #7
ex-x-fire
The shim has to fit the wheel bearing mounting flange pattern.
No factory rear alignment gear? bad DIY / Maintenance / Service 6 01-28-2015 12:21 PM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 10:35 AM
WOW What a difference an alignment makes!! YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-12-2009 05:29 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
