Old 07-31-2020, 06:41 PM   #1
ThrowingChicken
Drives: 2007 Toyota Yaris
Can anyone point me to a replacement clip for the vent hose on a 2007 Yaris?
This clip broke while replacing the fuel pump. Tried taking it to Autozone and the parts specialist at ToyotaPartsDeal.com, but none of them could ID it, and I couldn’t find anything in the service manual. Anyone have a part number or know where I can get one? Thanks!
File Type: jpg F7152DE8-C632-4C79-87EC-F6CF453A8E9E.jpg (93.8 KB, 41 views)
ThrowingChicken is offline   Reply With Quote
Old 07-31-2020, 07:11 PM   #2
Brighton
Knower of little
Drives: None
Dorman HELP! parts should have it. It's just a fuel line retainer, usually when you buy a new pump it comes with new ones, so it shouldn't be too hard to find. You could also potentially create something else to do the same job. If you look on the neck that the hose snaps onto, theres a slot that the retainer latches into. All you'd have to do is find a secure way to jam the line from popping off from pressure.
On second thought it should be a very similar if not an identical part across the toyota line, so I wouldn't rule out parts that don't explicitly say they don't fit your model, as long as they at least fit toyotas of the same age.
Brighton is offline   Reply With Quote
Old 07-31-2020, 07:43 PM   #3
ex-x-fire
I did some googling and all I can say is Toyota parts illustrations suck.
Old 07-31-2020, 09:23 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Maybe this?
https://parts.toyota.com/p/Toyota_20...724160320.html
https://parts.toyota.com/a/Toyota_20...1470-7701.html
Possibly P/N 7724160320
Old 08-01-2020, 04:52 PM   #5
ThrowingChicken
Originally Posted by 06YarisRS View Post
This is the closest I've gotten to it so far, but I think that is for the smaller yellow clip that holds the fuel line.
Old 08-01-2020, 06:48 PM   #6
06YarisRS
Could it be part of this assembly?
https://parts.toyota.com/p/Toyota_20...720952101.html
If it's not, could you not find a piece of suitable diameter wire/soft bendable aluminum rod or such and make a "U" shaped clip. I assume the clip is designed to keep the hose from backing off under pressure? Then again, you don't want fuel spewing around under your back seat.
Old 08-01-2020, 06:52 PM   #7
ThrowingChicken
If it is, it would probably be part of this one. The illustration/product photos are almost no help, unfortunately.
https://parts.toyota.com/p/Toyota_20...740452050.html
Old 08-01-2020, 06:57 PM   #8
06YarisRS
Ah, I must have been looking at the wrong hose. Well, looks like you're getting closer anyway. And, yeah, the part sketches pretty much suck.
Yaris 2007 (UK bought) Key Fob replacement sdfsdfsd General Yaris / Vitz Discussion 4 01-25-2016 05:44 PM
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
