Old 08-20-2020, 06:53 AM   #1
lorne
Drives: 2007 1.3L AWD (auto) Vitz 5 dr
Coolant Temperature Gauge Anyone?
Has anyone installed an analog coolant temperature gauge? I'd like to know exactly (more or less) what is happening — at least more than the LED tells me. Japanese summers can be hot and very humid.
I'd ideally like an oil pressure gauge and an oil temperature gauge, but for now I'd be satisfied with knowing what my coolant is doing.
I did a search and nothing came up. I'd be reassured by hints of how to rig it up on a Yaris.
lorne is offline   Reply With Quote
Old 08-20-2020, 07:34 AM   #2
stidnam
Drives: Starlet
Couple of options. You can put an inline temp sensor in the bottom or top radiator hose or you could buy a OBD2 gauge like an aem x-series or a scangauge
stidnam is offline   Reply With Quote
Old 08-20-2020, 10:07 AM   #3
lorne
Thanks ... those are some options I've not been aware of. I'm behind the times.
Old 08-23-2020, 04:45 PM   #4
ohms
Drives: 07 yaris 3door
get a cheap bluetooth OBDII reader - it plugs into the obd port, and then get an app for your phone (there are several - try dashcommand or torque to start off with) and you'll be able to see quite a few things that the car already has sensors for (water temp being one of them)
ohms is offline   Reply With Quote
Old 08-24-2020, 07:01 AM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Torque is a great app! For under $20.00 (app and OBD2 bluetooth adapter) and you can see so many sensor data points. Unfortunately, Toyota ECUs (at least the Yaris) won't give up data on trans temp, oil temp, oil pressure via OBD2. I installed dedicated gauges for these parameters.
Old 08-26-2020, 12:52 PM   #6
lorne
WOW ... you sure did! I don't think I will be following you. But it sure looks what I would like! Well, not quite. My 2007 1.3L AWD AT type is a pretty sedate, boring driver. Still, coolant temp would be great — even if I can't have oil temp and pressure.
This may be a dumb question, But is what your suggesting mean I have to know the port entries for the scan connection, and then have my smart phone reading something — I'm not really understanding, because I've been driving dinosaurs for so long.
What is a (or the) coorect coolant & amount for a Yaris? RMcG DIY / Maintenance / Service 0 06-19-2019 05:36 PM
Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? zimso General Yaris / Vitz Discussion 3 10-19-2010 07:17 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
Temperature gauge fearturtle44 General Yaris / Vitz Discussion 1 05-18-2006 08:54 AM
