Old 06-07-2007, 03:55 PM   #1
tacsnier
Is it worth undercoating a new Yaris?
Is it worth undering coating a new Yaris? Why?... btw I live in Canada, so in winter we get salt on the road... although I am trying to save every penny, but if its something worth doing before I pick up my car then I will get it done... thanks for your opinions!
tacsnier is offline   Reply With Quote
Old 06-07-2007, 04:02 PM   #2
Rizzo
Rizzo's Avatar
Drives: 2007 5-Door Hatchback
I live in Northern BC and they did it automatically. From the description I'm sort of happy they did, because not only does it protect against the rock, ice chunks, salt, etc, but it (allegedly) makes the ride a bit quieter on not-so-smooth highways. And it definitely keeps some warmth in.
Rizzo is offline   Reply With Quote
Old 06-07-2007, 04:29 PM   #3
Vervepipes
CowCountry Hornet Handler
Vervepipes's Avatar
Drives: '08 Sedan
get it done when it's brand new so there is no dirt or chips yet that can make it less effective if you choose to do it in the future
Vervepipes is offline   Reply With Quote
Old 06-07-2007, 09:23 PM   #4
kaboom
kaboom's Avatar
Drives: 2007 silver yaris sedan
Generally modern cars do not need undercoating. Underbodies are lined with bitumic compounds. Also - due to usage of galvanized sheet metal, there's no need to do "oil spray". Hope it helps.
kaboom is offline   Reply With Quote
Old 06-08-2007, 07:11 AM   #5
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Consumer Reports advises against it.
Old 06-08-2007, 09:02 AM   #6
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
We always undercoated new cars when I was a kid to protect against corrosion. With new manufacturing techniques/metal finishes it is not necessary. It will dampen interior noise to some degree in certain applications, but you also risk trapping moisture causing moisture. If you want to darken the inner fender well I would be more prone to a thorough cleaning and flat black paint application myself.
blacksan is offline   Reply With Quote
Old 06-08-2007, 09:14 AM   #7
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Originally Posted by blacksan View Post
... but you also risk trapping moisture causing moisture.
Oooooooh..!! Moisture causing moisture! Sounds cyclical!!
(Sorry! )
2006 Red Blitzed RS 5-door
Old 06-08-2007, 09:19 AM   #8
blacksan
blacksan's Avatar
(Sorry! )
Not enough coffee yet, I meant to say moisture causing corrosion. Dam you sharp witted morning dwellers!
Old 06-10-2007, 08:05 PM   #9
Thotprawsis
Drives: '07 Blazin' Blue LB
Put the money into sound deadening. You'll get improved stereo performance.
Thotprawsis is offline   Reply With Quote
Old 06-11-2007, 09:25 AM   #10
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
For sound deadening, tear off those inner panels and slather copious amounts of DynaMat or something like that. That's the most effective way to soundproof.
Of course, noone said that was the cheapest...
YarisTom73 is offline   Reply With Quote
Old 06-12-2007, 12:20 PM   #11
grampi
Drives: Corolla
Who's noone?
grampi is offline   Reply With Quote
Old 06-12-2007, 11:03 PM   #12
petesimac
Drives: Yaris LB
petesimac is offline   Reply With Quote
Old 06-13-2007, 08:52 PM   #13
TLyttle
TLyttle's Avatar
Noone is they's cousin... as in "they"say.
What's my Yaris Worth?? mtntoy General Yaris / Vitz Discussion 3 06-04-2007 12:30 PM
Is the Yaris Hatchback Worth It? Where is my Yaris? New YARIS Purchase Forum 23 03-26-2007 05:33 PM
