Old 09-09-2020, 08:43 AM   #1
Demon_S8
Drives: 2012 Yaris
Blitz install wiring inquiry.
Hello all,
I've recently acquired a Blitz supercharger for my 09 AT Yaris. The used kit came with most of the parts including the actual ECU infused in harness connections from donor vehicle, the fuel controller, blue injectors, minus the low-med-high - -Selector Switch. The person who I purchased the kit from is uncertain if the kit had said switch.
My issue is I don't see where I would connect this Switch, as the only unconnected wires apparently go to the relay that engages the clutch.
Do I need the Selector Switch for the clutch to engage, if so, does anyone know how to wire the kit without Switch at one setting, Low rpm engagement.
Thanks in advance for the support!
Demon_S8 is offline   Reply With Quote
Old 09-09-2020, 07:27 PM   #2
Demon_S8
Drives: 2012 Yaris
Added kick in the shorts... Apparently the Activation Box is also missing from the kit. Is this completely necessary for unit to work? What options if any do I have? Thanks!
Old 09-11-2020, 02:17 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got a thread around here somewhere with a schematic for making your own selector switch. The original one is just a few resistors that make a voltage divider for an input on the "piggyback" Blitz controller.
Old 09-11-2020, 02:20 PM   #4
CrankyOldMan
Some passive electronics knowledge helps, but it's pretty straightforward to replicate what came with the kit.
https://yarisworld.com/forums/showthread.php?t=50163
Old 09-11-2020, 11:46 PM   #5
Demon_S8
Drives: 2012 Yaris
Great, thanks!!!
Would you happen to know where pins 3 4 5 from the Selector Switch terminate in the Activation Box? ~~ Wires A & B -- Yellow & Black~~
Old 09-14-2020, 09:09 AM   #6
CrankyOldMan
I'd have to find the kit in the garage first, might have time this week to take a look.
Old 09-14-2020, 04:32 PM   #7
Demon_S8
Drives: 2012 Yaris
MUCH appreciated.
Wiring diagram for Blitz Bill18 Forced Induction Forum 1 09-12-2016 08:44 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Just another Blitz S/C install CrankyOldMan Performance Modifications 8 05-17-2013 04:07 PM
