Old 09-18-2020, 08:57 PM   #1
spoonzz
Drives: 5D YR 2012 Auto
side mirrors with indicators on 2012 Yaris help
Hi all,
So I've been giving my 2012 yaris a little face lift and would like to change the stock side mirrors to side mirrors with indicator lights however I have no idea how it should be done.
This is what the stock lights and connection look like -
https://i.ebayimg.com/images/g/GBAAA...se/s-l1600.jpg
And these are the ones I'd like to have one day -
https://image-cdn.beforward.jp/autop...230_f1c5df.jpg
https://image-cdn.beforward.jp/autop...230_0b2735.jpg
Does anyone know what's required to get this functioning as 'normal' aka electronic mirrors and having the indicators work. I am assuming, half of the connection (the circle) would have to be wired to the original connections for the electronic mirrors to function?
And for the indicator lights, I'd assume the little square connection would have to be wired and tap into the indicator lights? I have no idea haha.
Thanks
spoonzz is offline   Reply With Quote
Old 09-18-2020, 11:44 PM   #2
stidnam
Drives: Starlet
First of all you'll need the plug ends that match the JDM wiring. The plugs required can be acquired from a zre182 corolla here in Australia. You'll also need a new mirror switch if these are the electric folding type.
As far as wiring goes, you should be able to make a loom up that runs from the mirror switch to each of the mirrors that goes the electric folding sorted. This would have to be spliced into an ignition power source, possibly triggering a relay to run that switch. You'd then have to locate and splice into the side indicators. However, I'm not sure if you'd be able to run both the side indicators and the mirror indicators at the same time, or whether adding two additional indicators will screw with the resistance on those circuits.
I was originally looking at buying the mirrors purely for the electric folding function as opposed to the integrated indicators. While they look better, I don't think it's worth the hassle.
stidnam is offline   Reply With Quote
Old 09-19-2020, 09:19 PM   #3
spoonzz
Thanks appreciate the response and information!
They fold? I had no idea! I just wanted the indicator lights and still have the function of being able to move the mirrors with the switch.
Old 09-20-2020, 12:59 AM   #4
stidnam
Drives: Starlet
Not all of them fold, but the ones with 7 wires (from memory) do have electric fold. It's not auto though and is driven from a button on the mirror switch. You can get the same switch from a zre152 (2010 - 2012) corolla.
Old 09-20-2020, 07:28 PM   #5
spoonzz
Thanks, I'm gonna see if I can get the connection plugs and switch from a wrecker and work from there
2012 yaris 2d door panel removal Cryodrake Cosmetic Modifications (Exterior/Interior) 7 12-03-2016 03:47 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
My 2012 Yaris review... CanIHazYarisHatch? Third Gen Yaris General Discussion 35 02-20-2012 01:03 PM
