Old 09-21-2020, 03:31 PM   #1
osse
Drives: Vitz
Vitz 2008 Instrument cluster connectors pinout help needed
Hi Folks,
I am looking for a pinout diagram for the two connectors under the dashboard instrument cluster (as per attachment, this is not 2008 vitz, but just to show which wires I mean, as they are similar...). I am especially interested to understand if the engine, battery, airbag, etc. lights are powered by the separate wires. Thanks in advance!
osse is offline   Reply With Quote
Old 09-21-2020, 09:29 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There isn't really a simple way to get it other than dig through the wiring diagrams. It may be worth your while to get a 2-day subscription to the Toyota Tech Info service so that you can download all the manuals and diagrams for your exact model for offline use and verify that you have the correct info. If you're trying to swap in another Toyota cluster you can get the info for that one while you're in there.
Old 09-24-2020, 06:01 AM   #3
osse
Drives: Vitz
Thanks for the reply, I've tried reading the diagrams but can't figure out the pinouts on the connector. I think I will start debugging by extending the connector wires and disconnecting one by one.
Old 09-24-2020, 03:37 PM   #4
CrankyOldMan
The EWD has a pretty good explanation/legend section that shows what all the symbols mean. It takes a bit of detective work to find all the pins on any given connector because they're grouped by function to make troubleshooting whole systems easier. If they're .pdf's you can use the search function with some success.
Old 10-15-2020, 02:37 PM   #5
Ammar
Drives: Vitz 2009
Hi. I converted manual cluster to digital but m not getting average etc functions. Any help?
Ammar is offline   Reply With Quote
instrument cluster, instrument panel lights, wiring diagram
Instrument cluster light chriscruz2006 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-26-2014 11:29 AM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
2007 yaris instrument cluster rslyk Willing to Buy by private party 6 11-07-2008 01:41 PM
Instrument Cluster Stoln General Yaris / Vitz Discussion 2 06-23-2007 01:43 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
