Old 10-03-2020, 02:12 AM   #1
ravipasupuleti
Drives: 2013 Yaris LE
Question Does ECU flash really work, Please suggest
Hello Everyone,
Thank you so much for all your support here . All of you inspired me in many ways. I absolutely love my 2013 Yaris hatch auto and want to enjoy more of it. I have done a bunch of mods. I am looking for options to increase low end torque (stop sign to 40 feels sluggish ) i reached out to a guy in PR and he claims can do an ECU flash for stock setup. Does an ECU flash really help ? any idea on approx gains (if any) with stock setup.
Here are my mods done so far. Please suggest any mods that might help improve the low end torque.
1. 1ZZ Throttle body swap. ( car is surely peppy after this ).
2. Tanabe Medalion Touring Exhaust Axle-Back
3. Android radio install with back and front camera.
4. Auto dimming rear view mirror
5. Side mirror turn signals install.
6. Headlights assembly swap with 5K bulbs.
7. allow wheels.
8. Tach Install.
9. Under dash led strips, Shiftknob swap.
10. center console arm rest install.
ravipasupuleti is offline   Reply With Quote
Old 10-08-2020, 11:18 AM   #2
ravipasupuleti
Hello Gurus,
Can someone please suggest.
Old 10-17-2020, 02:43 PM   #3
bob225
A remap will release the power, exhaust and TB will not do much without it
A proper remap is require to take advantage of those mods, dont be surprised if you're running out of fuel due to the lack of pump and/or injector
Yaris world is very quiet these days so please be patient
bob225 is offline   Reply With Quote
Old 10-17-2020, 11:31 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Pretty sure the pump and stock injectors will handle those mods. I'm running a 2ZR 1.8, 440cc injectors and boosting 8 psi on the stock fuel pump and still get 11.5:1 AFR. Yeah, lots of headroom. OP, please share the contact info of your Puerto Rico guy that can remap the ECU. I've spoken to people who claim to have 'cracked' the ECU, but no definitive explanation of which parameters they can change. I'm waiting for the crack, so I can ditch my aftermarket engine management.
Old 10-17-2020, 11:50 PM   #5
ravipasupuleti
Thank you for the reply.
I spoke to a guy from Wilson chips, communicated with him on email and phone ( details below). He said, they can pretty much remap everything ECU based on our requirement.
He claims they dyno tested the parameters, since mine is a stock setup, he would program it accordingly.
email : wilsonchips@yahoo.com
phone : 787 868 1351
Old 10-18-2020, 07:46 AM   #6
06YarisRS
That's great! Thanks very much. I'm going to give them a call early in the week.
EDIT: I went to their Facebook page and see that I had sent them a message in 2019. Wilson was mentioned here on Yarisworld before. Anyway, they didn't respond to message, but I did speak with an outfit (might have been them) that suggested I send my ECU to them. For around $250.00 USD, they would look into my ECU to see what was able to be modified.
Old 10-18-2020, 09:14 AM   #7
ravipasupuleti
Great, apart from ECU flash. Is there any piggyback ecu swap available. Just checking to avoid tampering the stock ECU
2013 Yaris LE, 5 Door. Custom Wheels, 2ZZ TB Swap. Planning for a 2ZR swap in future.
Old 10-18-2020, 09:46 AM   #8
ravipasupuleti
Just got a reply from Wilson chips . They tweak AFR, timing, rpm , vvtli,vvti,throttler, DTC AND MORE.
Old 10-18-2020, 09:23 PM   #9
06YarisRS
Yes! I started a chat with them through Facebook. He tells me I need to keep the AEM F/IC piggyback for fine tuning the fueling. He also mentioned a maxxmini ECU. Planning a call to them tomorrow. I'll post back what I find out as well.
Old 01-29-2021, 01:39 AM   #10
Neinris
The guy at https://frankensteinmotorworks.squarespace.com/ can tune Toyota ECUs. He mostly does 2ARs or 2GRs, I'm pretty sure he can do 2ZRs, but he seems too busy with his channel, so I don't know if he'd be willing to do it.
rear sway bars for 3rd gen "real" yaris baseballfan416 Third Gen Yaris General Discussion 3 09-27-2020 09:43 PM
Asking a quick favour from 3rd Gen Owners kuveris Third Gen Yaris General Discussion 9 03-16-2016 12:08 AM
1st Gen ECU Options Ryze268 Performance Modifications 4 04-08-2014 12:29 AM
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
Which of These Car Companies Will Go Bust First? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 11-16-2008 10:50 PM
