Old 06-07-2007, 08:23 PM   #1
Boy Blue
Boy Blue's Avatar
Drives: 3Dr H/B
Lowering alignment/rubber on springs
I have a set of TRD (eibach) springs installed. the rear one's have a platic coating around the spring tubing, is that suposed to be at the bottome or the top when installed.
2nd question is... now that i have dropped it and added 15's do i need to do an alignment on the car.
thanks a bunch
Boy Blue is offline   Reply With Quote
Old 06-07-2007, 08:39 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I would assume the bottom, read the instructions, call the manufacturer.
Don't -have- to align. No.
SPONSORED BY
Old 06-07-2007, 09:49 PM   #3
webomatics
webomatics's Avatar
Drives: SILVER BULLET
It is always recommended to do alignment when you drop your car, with that said I have NF210 on mine and didn’t do it and did not feel a difference.
webomatics is offline   Reply With Quote
Old 06-07-2007, 10:26 PM   #4
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
i had the df and it needed a little ajustment ..
OxyG3nE is offline   Reply With Quote
Old 06-08-2007, 08:00 AM   #5
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
thanks a bunch
1. Bottom
2. I need it alignment after doing the DF drop, won't hurt to check it
YamilR is offline   Reply With Quote
Old 06-08-2007, 09:11 AM   #6
Boy Blue
Boy Blue's Avatar
Drives: 3Dr H/B
So if the rubber coating is at the bottom then the "Eibach" name is to be upside down? Currently They are installed so the eibach print right side up so the rubber coating is at the top of the spring.
I am not worried about my steering response, that alignment is fine, i am more concerned about tire wear. I will go and have it aligned, better safe then sorry.
Old 06-08-2007, 09:31 AM   #7
brickhardmeat
Lonesome Cowboy
nothing wrong with having it aligned but you may not need it, they'll check it for you
i would think the name would go right side up, CALL THE MANUFACTURER
SPONSORED BY
Old 06-08-2007, 09:58 AM   #8
Boy Blue
Boy Blue's Avatar
Drives: 3Dr H/B
OK OK Brick... i get your point... i will give them a call.
Old 06-09-2007, 06:51 PM   #9
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
the rubber is there in the middle to prevent rubbing of the spring where the compression points (can't think of how to say it right) would normally touch. kind of like a bushing.
the eibach name is upright on the spring, therefore the name should be readable if the spring is installed correctly.
and yes get an alignment. even if you don't feel anything that doesn't mean the wear of the tires is correct or the suspension is geometrically sound.
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
