Old 10-04-2020, 10:04 PM   #1
remcafee
alternator crooked
when i tighten up my belt my alternator start pivoting a little bit crooked, i cant tighten my belt up, help!
Old 10-05-2020, 07:07 AM   #2
ex-x-fire
Is anything bent? We might need pictures.
Old 10-05-2020, 01:39 PM   #3
remcafee
my lower bolt is bent, i bought a new bolt at the dealer and still tightens up crooked
Old 10-05-2020, 09:42 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I had a similar issue with a broken alternator mounting bolt on the 2ZR--sheared off at the nut and allowed the alternator to sit a little crooked. Started throwing belts when I got on the gas. If the bolt is bent inside the mounting boss, you may have to pull the bumper cover and radiators out to get at it.
Old 11-06-2020, 09:05 PM   #5
remcafee
well it turns out i need a new engine block, cause where the alternator goes over the block there is a section thats indented ineards and causes the alternator to sit crooked, this is where im at with my life :(
Old 11-06-2020, 09:51 PM   #6
ex-x-fire
We need pictures! Maybe you can shave the area flat and shim it to make up the space.
