Old 10-09-2020, 09:59 AM   #1
Pinchlite
Drives: 2007 yaris HB
3 prong headlight high low ?
I have the DRL unplugged first off.
If looking at this https://i.imgur.com/uJaZkyi.jpg
What wire would be high low?
Looked to long on google cannot get proper answear
For specific yaris only/
Pinchlite is offline   Reply With Quote
Old 10-11-2020, 01:54 AM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I'm not sure if I got this correct - are you asking how the light is switched?
If that is the question, the commin pin is conected to positive 12 volts and either the high or low beam pin is earthed to turn the light on.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 10-11-2020, 06:56 AM   #3
Pinchlite
Low -high beam wire
I am asking..if you look at an actual yaris 3 prong headlight connecter which pin is high and which pin is low beam.
The picture is just an example/visual.
Old 10-11-2020, 08:43 AM   #4
BLH
Drives: 2007 Yaris Sedan
The headlight bulb is a 9003. The photo you posted matches the 9003 bulbs pin out.
Are you needing the actual pins wire colors? They are different between the drivers and passengers side headlamps.
Each side has its own fuse to feed 12 volts into the common pin for that side headlight. You tie the high or low beam filament to ground to light it.
Old 10-11-2020, 08:51 AM   #5
Pinchlite
Rephrase question!
Let me rephrase the question in hopes of figuring this out..
What color of wires are what.
Remember the pic I posted is RANDOM.I have no idea from what car it is from>
New question.
What wire color is low and what color wire is high beam..
For both left and right 3 prong connectors.
Old 10-12-2020, 06:03 PM   #6
BLH
For 2007.
Left Hand. Green Low Beam,Brown Hi Beam,Grey Common.
Right Hand. Blue Low Beam,Green Hi Beam,Black Common.
Old 10-12-2020, 06:06 PM   #7
Pinchlite
H4 9003
Thankyou!
Coul not find diagram showing actual colors.
I suppose I could have used multimeter to check voltages,but wanted definitive by wire color.
Thanks again.
Low and high at a Jeep meet :) Exiwolfman Off-topic / Other Cars / Everything else Discussions 10 07-04-2014 10:49 PM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
