Old 10-11-2020, 08:21 PM   #1
cdilmore
Drives: 2010
Fuel Spews at fill-up
Hi!
Every-every time I fill up, the pump auto-shuts off... and fuel spews from the filler - down the car and to the pavement. I'm guessing a fuel vent may be clogged, but not sure if it's a pipe, other component?
Notes:
. Happens at every gas station - every pump.
. No Check Engine Light - ever.
. It's always happened. I'm now at 135K miles.
Thanks!
Chuck
2010 Yaris
cdilmore is offline   Reply With Quote
Old 10-17-2020, 12:58 PM   #2
Mister
Drives: Yaris T1
I think the Yaris Ninjas said it is because you overfill the tank past the first click?
https://yarisworld.com/forums/showthread.php?t=61503
check charcoal canister?
I had a similar problem due to overfilling. I would have to pour petrol slowly and sometimes with a jerry can
Mister is offline   Reply With Quote
Old 12-03-2020, 12:16 PM   #3
IndestructibleYaris
Vent clogged or tube kinked? Check ball somewhere is not opening? Take vent tube off and force air through it and see if you can feel it coming out of fillerneck
IndestructibleYaris is offline   Reply With Quote
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Accurate fuel fill without topping off? sbergman27 Fuel Economy Forum 25 02-11-2012 03:58 PM
