#1 |
![]() Drives: Yaris 2006 NCP91R Join Date: Apr 2020
Auto Transmission Leak
So after recently changing the fluid, filter and pan gasket I've noticed a leak but it appears to not be the result of the pan as I've ran my fingers slightly above where the pan meets and felt fluid
It appears to from above through those connections. The second picture is just above the transmission I'm not too sure if this issue was there before changing the fluid etc. Anyone have an idea what that could be? Last edited by Branderrp; 10-27-2020 at 03:48 AM. |
![]() ![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Could you have spilled some when filling it up?
#3 |
I'm starting to think it could be a spill
I may leave it for a few days to see how it goes (the rate of leak it's very low) Do you think I should look out for anything in particular? |
| Auto transmission leak? | mtshum | DIY / Maintenance / Service | 0 | 07-24-2020 12:02 PM |
