Old 10-30-2020, 12:40 PM   #1
mrfudgeu
Drives: yaris 2015
2nz-fe engine
Yaris 2016
Engine:
2nz-fe 1299mL
This engine is installed used since when?
I read somewhere that its since 2005/2006 same engine...
True?
Nothing changed?
Same quality too?
Cuz i see older Yaris’s still run smooth & like a clock...
My ride is around 210,000km
& im starting to here sounds in the engine...
Even though i drive normal or slow(mostly)
Is there a better & longlife & economic.. toyota/lexus engine that I could install in my car? Even if its old?
I heard a 91s camry engine can take a beating & run like a clock...
Or other suggestions?
No plans on selling it incase its a suggestion...
mrfudgeu is offline   Reply With Quote
Old 11-03-2020, 07:41 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Originally Posted by mrfudgeu View Post
Yaris 2016
Engine:
2nz-fe 1299mL
True? YES TRUE
Nothing changed?
Same quality too? SAME QUALITY
& im starting to here sounds in the engine... WHAT KIND OF SOUNDS
what is your issue?
i have same 2nz-fe in my yaris 2016 and we are both in saudi. i think mine has the single VVTI. the new yaris 2017 above uses different engine with dual VVTI. mine is at 106k KM now after 4 yrs of use... runs like bnew... can barely notice engine sound when the AC is off.
just did normal maintenance by full syn 5w30 lube oil changes every 8-10k km and plug changes every 20k km... never had a problem except for the evaporator which had a premature failure (pinhole leak at 3yrs 1 month).. aside from that everything runs smooth... i regularly cleaned my throttle body every year.
rayfloyd170 is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
