Old 10-31-2020, 10:44 PM   #1
l4d2mayhen
Drives: yaris
Issues with rear adjuster
Im kinda new here so i will be as detailed as possible.
So i replaced my brakes front and rear like 2 years ago, no issues with the front, the rear adjusters that came with the brake kit worked for a while then one of them doesn't move freely so i changed them both, few hours ago, rear adjusters turn backwards.The rear is a pain in the ass especially the auto adjusters. I keep losing rear brakes because the auto adjusters instead of expanding it contracts (the star wheel turns inside instead of turning outside), im not sure what causes it. It used to be both but i replaced both of them at the same time, same brand, left side automatically adjust, but right side starwheel still goes backwards. i need help because winter is coming and im exhausted with ideas on what causes this thing.
PS. I knew that i put them in the correct side and orientation, both of them has a stamp of L and R, and adjusters only go one way.
Any input is highly appreciated. Thanks
l4d2mayhen is offline   Reply With Quote
Old 11-01-2020, 07:22 AM   #2
ex-x-fire
Sounds like they were stamped L-R wrong.
Old 11-01-2020, 02:46 PM   #3
l4d2mayhen
Drives: yaris
Thanks for the input but i bought another set from amazon and actually compared the L and R, they have the the same stamps but still starwheel still spinning backwards
Old 11-01-2020, 04:57 PM   #4
You need to find a way to get some pics of your brake install up. This is not making any sense.
adjusters, brakes, rear, rear brakes
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 54 04-24-2026 08:40 PM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
Exhaust clearance issues... YaYa1320 Performance Modifications 12 10-07-2009 04:46 PM
