Old 11-01-2020, 12:01 AM   #1
senioryaris
Drives: 2019 Yaris LE hatchback
LED headlight h4/hb2/9003 compatible with drl
For Yaris 2019
Still looking for a LED headlight h4/hb2/9003 compatible with drl
Lots of misleading claims about compatibility with drls...
So if you have a good info, post it here!
Please, no commercial spamming
Prefer Amazon or Aliexpress for obvious reasons.
Cheers, Adam
senioryaris is offline   Reply With Quote
Old 11-01-2020, 12:09 AM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I wouldn't bother with the Amazon, ebay, etc junk. They never last and they just blind other people.
But, if you're dead set on LED headlights in reflector housings, spend the money and get a set of Morimoto 2strokes. They sell anti-flicker modules for them too.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 11-01-2020, 11:41 PM   #3
01lexpl
Drives: 07 sedan
I'm not sure about the 2019's... I'd imagine they're the same... But these flicker.
I bought a set of (good) LED's and they flicker. Installed the resistors, still flickered... I was stumped, so i left them alone... In lowbeam mode they're fine...
01lexpl is offline   Reply With Quote
Old 11-02-2020, 07:49 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Are you looking to replace the globes for appearance or function?
The LEDs will give a "whiter" light than the halogen globes, but will most likely not give a well defined light pattern. Many (most?) of the claimed light outputs are greatly exaggerated on eB**.
If you are looking for better light output, consider a set of Philips X-treme Vision globes. I have these in my 3rd gen Yaris, and they really light up the road on high beam without blinding oncoming traffic on low beam. You should also probably check the alignment of your headlights. Mine were set too low, while the high beam lights on my Camry were aimed up in the air, and did not even light up the road.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-02-2020, 11:31 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I second Xtreme Visions, I run them in my F150 and ran them in my Yaris before I retrofitted, they are BRILLIANT. If you can find Racing Visions in your size, get those. They are even better, but they don't last as long.
2014 NCP131 5 Speed
9003, drl compatible, hb2, headlight, led
Yaris DRL Halogen Bulb LED replacement todorakiggg DIY / Maintenance / Service 10 11-02-2016 09:00 AM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Does anyone realize yarisworld is getting 'less busy'? caineroad General Yaris / Vitz Discussion 84 11-05-2013 12:19 AM
Yari gets a sway bar and a rim change (again) D&D Photo-Video-Media Gallery 8 09-16-2013 01:10 AM
