Old 11-02-2020, 07:55 PM   #1
918audio
Drives: 07 Yaris Sedan, auto.
'**HELP** 07 & '10 Sedan Meter Swap Issues
Ok, so Im wanting to swap out my meter (instrument cluster) for a meter from a '10 Sedan that is at my local salvage. PROBLEM: when I look up to see if the '10 meter will fit mine it tells me that "doesn't fit". However, the one that does fit mine, fits the 08 & 09 and the '10 does as well. So can anyone please explain to me why its telling me why the '07 & '10 wont interchange, when both will fit the 08 & 09?? Oh and I probably should include that mine has the speedometer only and the '10 has the combo tach/speedo.
918audio is offline   Reply With Quote
Old 11-02-2020, 09:08 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Where are you "looking up" the compatibility? The only way to know for sure is to get a copy of the electrical wiring diagram (EWD) from Toyota and check all the wiring connections, or just buy one and plug it in. =)
Old 11-03-2020, 03:03 AM   #3
918audio
I was on the Toyota parts site
Old 11-03-2020, 01:02 PM   #4
CrankyOldMan
Gotcha. I haven't looked at sedan clusters before so I'm not sure what might be different. I swapped my hatch cluster to one with a tach a long time ago, it was just plug and play.
If you have a you-pull yard nearby with one in stock you can use that to see if it works and take it back if it doesn't.
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
Tire: 2009 Yaris Sedan Base OR S Sedan cagesd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-21-2016 07:34 PM
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
