Old 11-30-2020, 07:21 AM   #1
komichal
Wheel huming below 0°C
Hi All,
When driving below 0 °C (32 °F) faster than 70 km/h (44 mph) I hear a deep humming from the right tyre (not sure if front or rear). It started last winter. I thought that my winter tires were noisy because they were already dead so I bought 4 new ones for this winter (Kléber), however it did not help a single bit.
I also changed pads and rotors this summer - again no change between the two winters.
Naturally I suspected also the wheel bearing, however I have no clue why it would be noisy only in low temperatures. Moreover - front wheel bearings were both changed 3 years ago (some 30,000 km/18,500 miles) for a quality brand (SNR) which I expect should last a lot longer. Visual inspection of rear bearing did not reveal any suspicious behavior but surely under load things can change.
Before taking a blind shot and replacing the rear wheel bearing (100 USD for a a quality one here) I would like to ask you for additional opinions. The sound is really very similar to the one that a dead bearing does and is not anyhow linked to engine RPM, only to car speed. The car has driven total 180,000 km (112,000 miles).
Thank you.
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 12:19 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
