#1 |
![]() Drives: 2012 Yaris Join Date: Aug 2020
ABS light on dashboard
Hi,
My ABS light came on on the dashboard a week or so ago on my 2012 Yaris and I'm just trying to work out where the issue might be. I tried to scan using my Bluetooth odb2 dongle and my phone with fusion and auto doctor but I can only seem to get ECU codes. After a bit of searching online it does look like most Toyotas seem to have a self test system for ABS accessed by bridging pin 4 and 13 on the OBD2 like this: https://www.youtube.com/watch?v=PD1V6pv2ej0 and should it should give a code by flashing the abs light that hopefully will give me a bit of a steer to finding the problem. Just wondering if anyone can confirm if this will work on a 3rd gen Yaris, or is it only the older models? thanks |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
You need a OBD2 error code reader like this.
https://www.amazon.co.uk/Carista-Blu...NsaWNrPXRydWU= The really ones cant read everything.
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
#3 |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
The ABS unit has its own memory and is likely a system that your Bluetooth dongle doesn't have access to or can't read.
The best way to get to the bottom of the problem would be with techstream. Bridging pin 4 and 13 puts the car into a diagnostic mode. It works on The Yaris as well. It's these two pins you need to bridge actually to register a new ECU. I wouldn't be surprised if the same procedure to clear the abs codes works on the Yaris. Give it a go. No real harm if you bridge the right pins. Keep in mind that warning lights don't just come on for no reason. Could be an ABS sensor, the actual unit itself...who knows. |
#4 |
Thanks, just thought I would check with someone else to make sure I wasn't doing anything daft. Why do these things always happen just before MOT is due!?!
I just tried bridging pin 4 and 13 there and it flashes code 34 which corresponds to the left rear speed sensor. I also cleared the codes and went on a short drive and the light came back on again, with the same flash code. It'll probably be the weekend before I've time during the day to have a look at it though but I'm planning to do this:
I'll probably treat myself to a new ODB2 dongle as well, the one I've got is only a cheapie that I've had for about 10 years I think and something that can read ABS codes might make my life a bit easier! |
#5 | |
Good luck.
#6 |
Thought it was worth updating just in case someone comes across this again.
Replaced the rear ABS sensor (the full hub cos it was easier) and all was good. |
#7 | |
![]() Drives: Yaris TR Join Date: Oct 2021
Thanks |
| parking brake light on & abs light on ! car stuck in 2nd gear !!! | Bony_ahmed | DIY / Maintenance / Service | 3 | 04-29-2019 06:57 AM |
| Yaris 2001 The engine yellow/orange warning light in the dashboard | cabbage2001 | DIY / Maintenance / Service | 11 | 01-16-2015 06:53 AM |
| Brake & ABS Light On | JeffRapp | DIY / Maintenance / Service | 3 | 01-04-2013 11:10 PM |
| Sharing and Need Help! Lowered but abs light came on! | tobymak21 | California | 0 | 08-08-2012 08:48 PM |
| Toyota Yaris -06 VCC and ABS light went on? | goedafred | DIY / Maintenance / Service | 4 | 03-01-2011 12:22 AM |
