Old 02-04-2021, 05:41 AM   #1
kaypie
Drives: daihatsu sirion
Unhappy intermittent fuel pump start
Hi folks, newbie here - thanks for the great forum!
Hoping you can point me in the right direction.
My wifes Sirion (Yaris T3 engine) has a strange issue where the fuel pump only switches on intermittently. Initially I thought it was the fuel pump, so I replaced the Denso pump and filter for a new Bosch unit.
After replacement the vehicle started, idled, and did a long test drive without any issues, several test starts afterwards was also fine.
The car stood for a few hours, when trying to start it again the pump wouldn't switch on.
I'm still testing a theory whereby when I pull the EFI fuse for a minute and replace it, it allows the pump to switch on again (some sort of "reset"?)
Is there perhaps another relay or fuse I can check that could be acting up?
As part of the initial troubleshooting I checked the coils, spark, battery, fuses under the hood. I also disconnected the battery while changing the pump.
Hope you can help!
kaypie is offline   Reply With Quote
Old 02-04-2021, 05:59 AM   #2
kaypie
I've found this diagram for the internal fuse box behind the cubby, I noticed "Fuel Pump Relay" at the bottom left, so I guess it's worth replacing
File Type: png Screenshot from 2021-02-04 12-57-08.png (31.4 KB, 27 views)
Old 02-04-2021, 07:10 AM   #3
kaypie
Well I've replaced the relay for what its worth, still nothing :/
Fuel pump, sender, seal, wiring, and cluster mavrick DIY / Maintenance / Service 5 07-22-2019 05:34 PM
HELP: Swings but does not start after fuel filter replaced REV 2 11 DIY / Maintenance / Service 12 08-19-2013 01:38 PM
Fuel Pump Relay bronsin General Yaris / Vitz Discussion 4 08-07-2012 07:19 AM
