Old 02-04-2021, 09:31 AM   #1
maralieus
Drives: 2007 toyota yaris s
Heater blows very hot, coolant level dropping slowly.
I replaced the thermostat and refilled the system completely on my 2007 Yaris. It wasn't blowing heat at all before, but now it's blowing heat that after driving for ten minutes or so, becomes so hot you can't even put your hands in front of it. I think it's the water pump because it makes a low growling noise coming from that area, but it's only intermittent, and it stops if I turn the interior fans off, so maybe it is actually the fans? It's really hard to tell exactly where the noise is coming from. I don't have the money to replace every single part rn, I need to get it right. Any help would be appreciated so much. Thanks for reading!
maralieus is offline   Reply With Quote
Old 02-04-2021, 12:00 PM   #2
I'm thinking you have an air lock in the cooling system. That would explain the very hot air and levels dropping. Remove the rad cap and run the car for a few minutes to burp out any air which may be trapped. Top of the system, replace the cap and see if anything changes.
Old 02-05-2021, 09:08 AM   #3
maralieus
I'll give it a try
coolant reservoir/upper radiator level tmontague DIY / Maintenance / Service 4 11-05-2014 09:11 AM
heater not working water coolant level drops Mike Hancock DIY / Maintenance / Service 4 11-03-2011 02:14 PM
Inception (movie) Kioshi Off-topic / Other Cars / Everything else Discussions 25 08-10-2010 02:08 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
