Old 02-14-2021, 12:02 AM   #1
rayfloyd170
Drives: Yaris 2016 1.3 Manual
radiator assembly has play and creating mild noise
hi,
I have a gen3 sedan and i just want to know if the radiator assembly has a little play from factory or should be snug fit with the chassis.
I noticed there is a slight movement and creating a mild sound especially when the fan kicks in. I mean the whole assembly holding the radiator and fan moves if i try to push or pull it. i noticed this through the upper tabs not 100% snug fit too, the whole assembly has a little play maybe less than 1mm.
I dont know if this is still within tolerance or do i need to do something about it.
I tried checking the aux fan motor, alternator, water pump and all of them are good... Even elevated the frontend and rotated the wheels and found all bearings to be in good condition.
rayfloyd170 is offline   Reply With Quote
