Old 02-23-2021, 09:47 AM   #1
Kss0x00
Drives: 2009 yaris hatchback
Running rough after stereo install
I recently installed an after market (Chinese 7010b) stereo in my girlfriends 09 yaris which now seems to be idling a little rough and she says the steering is randomly "really tight"/ hard to turn the wheel. I wired the stereo according to the diagram, but there was a third connector plugged into the back of the OEM stereo that I can't find reference to anywhere (connector had 5 wires of about 20 possible openings for wires) that i just left disconnected. Car is manual transmission if that matters.
Is there anything related to the stereo that would cause these issues? Or does anyone have any troubleshooting ideas?
TIA
Kss0x00 is offline   Reply With Quote
Old 02-23-2021, 10:14 AM   #2
Did you have the battery disconnected while doing the install?
Old 02-23-2021, 10:22 AM   #3
Kss0x00
Yes the battery was disconnected. The instructions said to disconnect the negative terminal, but I completely disconnected it.
Old 02-23-2021, 10:44 AM   #4
In that case, the ECU must go through a relearning process to restore fuel and engine management settings. This requires nothing more than driving the vehicle. Eventually it will settle down to normal operation.
Old 02-23-2021, 04:29 PM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Wondering if grounding is an issue. When it is, the steering issue you described can be present...
On Instagram
On Wheelwell
Old 02-23-2021, 10:40 PM   #6
remcafee
alternator could of gotten a little weaker with the stereo install
Old 02-24-2021, 12:49 PM   #7
Leegamer
Leegamer's Avatar
I had a similar issue with my steering, it would get really tight as you approach lock and I finally noticed once I hit full lock the car would start to cut off for a second. The car was also running more and more rough.
When I started looking into it I had a lot of corrosion on the battery terminals. I cleaned them thoroughly and resolved both issues immediately.
I'm a hermit named Lee
Old 02-26-2021, 11:03 PM   #8
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
I have an 07 Sedan, manual transmission, same idle issue happens to me when I disconnect my battery, usually fixes up after a few hours, just drive cautiously, the car could turn off on you till the computer resets itself
Stereo Install Question xiii In Car Entertainment + Electronics (audio / video / alarm) 1 12-21-2011 01:08 PM
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
