Old 02-24-2021, 03:44 PM   #1
Rob888
Drives: 2010 Yaris 2 door hatchback
Key Copying Questions
My car is a 2010 Yaris 3 door hatchback. It has an immobilizer.
I have one master key and one valet key.
I want a third key so I can put the master key in storage so I don't lose it and only use it to make key copies.
The only Yaris keys that can be programmed without software are for the 2007-2008 model Yaris, correct?
From what I have read, using software like Toyota Techstream or whatever to program keys risks screwing up the car's computer, correct?
Getting a valet key copied is a lot cheaper than getting a master key copied. So can I use a valet key with a separate remote fob for the door locks instead of a master key with a remote fob either attached or separate? My glove box does not have a lock on it, and I never open the rear hatchback door with a key. I only use the key to start the car and the remote to open and close the door locks
Thanks for any replies.
Rob888 is offline   Reply With Quote
Key copying questions Rob888 General Yaris / Vitz Discussion 1 04-16-2019 10:33 PM
Question about adding another key and fob rcvmini DIY / Maintenance / Service 19 10-14-2018 09:17 PM
New remote key fob programming costica DIY / Maintenance / Service 1 04-17-2016 08:02 PM
2008 Toyota Yaris Immobilizer/Transponder Key ItsanEE DIY / Maintenance / Service 0 07-11-2015 03:48 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
