Old 06-08-2007, 11:23 PM   #1
gnetster
Drives: Yaris Sedan
High speed stability
Hi, I've got a Yaris sedan (not s). I purchased the car new and have had it for two weeks. Overall, I'm happy with the car. However, I'm noticing that at highway speeds of 65mph, the car feels a little rubbery. I've got 15" rims and 185/60 tires, that came with the car. Have any of you experienced this and if so, how have you addressed it?
gnetster is offline   Reply With Quote
Old 06-09-2007, 01:22 AM   #2
a lot of people here will probably say that a new set of rims, larger in width, and new, stickier tires will make the most difference. as for me, i went with lowering my car and adding a strut bar.
Old 06-09-2007, 12:44 PM   #3
grampi
Drives: Corolla
I think some have also said inflating your tires to 5 PSI over what's listed on the driver's door helps.
grampi is offline   Reply With Quote
Old 06-09-2007, 04:53 PM   #4
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Suspension Upgrade. If not Bigger or widder wheels.
I Drive a 129whp Yaris ;)
Old 06-09-2007, 05:03 PM   #5
flighttekchris
flighttekchris's Avatar
Drives: 2007 Yaris 3door
will "bigger or wider wheels" affect mileage?
flighttekchris is offline   Reply With Quote
Old 06-09-2007, 06:03 PM   #6
Mr.Yaris
Drives: 2007 "Flint Mica" S-Type
If they're heavier, yes. By how much? That's the real question.
IMO, "high-speed stability" is relative to what you're considering "high-speed" to be. I've had my Yaris @ around 100 mph, but IMO, that's not really all that "high-speed". I've been ~170 mph in my Camaro Z28. To be honest, if 100-120 is what you're referring to, your stock tires should be fine. Any faster than that, and you'll need to start buying the appropriate speed-rated tires, and maybe wider tires for cornering...
Mr.Yaris is offline   Reply With Quote
Old 06-09-2007, 11:55 PM   #7
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Theoretically rolling resistance may increase, especially in rain/snow because you have to displace more liquid.....in real life probably not.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-10-2007, 12:32 AM   #8
gnetster
Drives: Yaris Sedan
Thanks for the replies :-)
Old 06-10-2007, 03:47 PM   #9
thomasward00
thomasward00's Avatar
Drives: 2007 Yaris Sedan
I've just installed my new rims and tires, I went from the stock 15 inch steel rims to 16x7 with 205/50/16's and the difference when on the Interstate at 70mph is amazing, it isn't as darty in the wind, its a much more stable car now at speed. With the old rims and tires I didn't feel comfrortable in the Yaris when commuting, this upgrade has made all the difference in the world.
thomasward00 is offline   Reply With Quote
Old 06-10-2007, 03:50 PM   #10
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
SPONSORED BY
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
Finding a 5 speed LB to test drive grampi General Yaris / Vitz Discussion 16 05-10-2007 07:58 AM
Speed sensor for navigation install saue1436 In Car Entertainment + Electronics (audio / video / alarm) 5 04-12-2007 09:40 PM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
