Old 04-09-2021, 02:47 AM   #1
Neinris
Lower Control arm inner rear bushings
So it sounds like I need to replace the inner rear lower control arm bushing for my driver side. I thought it was my sway bar end links. I guess I might as well replace all four lower control arm bushings.
I was looking for maybe a polyurethane replacement to make it last longer, but the ones that I’ve found are solid, which doesn’t have the groove like the OEM to make it more flexible.
https://www.ebay.com/itm/Polyurethan....m46890.l49286
Should I stick with the OEM style?
Old 04-09-2021, 07:12 AM   #2
ex-x-fire
What kind of noise is it making?
Old 04-09-2021, 12:05 PM   #3
Neinris
It creaks and clunks over bumps.
Found a video of how to replace the bushings. At about 5:48 he demonstrates the creaking noise I was talking about.
https://www.youtube.com/watch?v=0jKcJMLEEPk&t=458s
Old 04-09-2021, 12:11 PM   #4
Neinris
Also, I found a polyurethane OEM version:
https://www.ebay.com/itm/06-18-Yaris....c101195.m1851
Should I get this instead of the solid one?
Old 04-09-2021, 05:50 PM   #5
remcafee
if you dont mind squeaking and creaks go poly, you can put all the lube ypu want on those, they still will make noise, they work fantastic though
Old 04-10-2021, 12:29 AM   #6
Neinris
Oh, I didn’t know that. I don’t want the squeaks and creaks, that’s why I want to replace the bushing to get rid of the noise. I’ll go OEM then, thanks for the info.
Removing lower rear spring perches? lormagni Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-26-2015 04:40 PM
Lower control arm bolt replacement sully DIY / Maintenance / Service 6 01-15-2015 09:49 AM
P1 rear wiper arm on P2 Chariz Cosmetic Modifications (Exterior/Interior) 1 10-12-2014 06:08 PM
