Old 04-22-2021, 04:21 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Performance Shocks/Struts?
Back in the day, I put Tokico HPs on my Yaris and they've been great. They probably have about 60,000–70,000 miles on them now, and will need to be replaced at some point. I'm not interested in running coilovers again.
So what are people running for "performance-oriented" shocks/struts? It looks like the TRD units are still available as are Bilsteins. Any others I should look at?
Old 04-23-2021, 01:56 AM   #2
Jason@SportsCar
If you can find a set, the Koni STR.T would be a nice option.
Old 04-23-2021, 04:29 PM   #3
Thirty-Nine
Did they ever actually make these for Yaris? I see Koni's site doesn't have them for Yaris.
Old 04-24-2021, 11:10 AM   #4
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
Just wondering how stiff in % are Tokico HPs compared to stock?
Fluxtasy is offline   Reply With Quote
Old 04-26-2021, 11:46 AM   #5
Thirty-Nine
I don't have any numbers, but they weren't just OE replacements. If I could get another set, I would personally. I've been happy with mine. I don't track my Yaris or stuff, so the HPs + Tein S-Techs are a good street setup.
Old 04-26-2021, 02:35 PM   #6
Jason@SportsCar
I have seen listings for them.
Old 04-26-2021, 04:37 PM   #7
Fluxtasy
feed my pet
Fluxtasy's Avatar
I just read up on another thread that its 15% stiffer than stock:
https://www.j-body.org/forums/read.php?f=3&t=153696&a=1
Old 04-27-2021, 09:24 AM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've been on Koni "reds" with MicroImage blue springs. Been pretty happy with them for DD and AutoX use, not sure what I'll do when they wear out.
Old 04-27-2021, 10:16 AM   #9
Neinris
Are the Koni reds you're referring to shorter than stock? I'm looking for something to marry my Tein's lowering springs with. Some have used Blistein, but might be a little too stiff for comfort, so looking for another option.
Old 04-27-2021, 10:54 AM   #10
Fluxtasy
feed my pet
Fluxtasy's Avatar
I have an option to go for a KYB model available domestically here but they are 30% stiffer than stocks. Probably too stiff as a daily.
If I do get them then I might have to swap back to stock springs and wear them down lol
Old 04-27-2021, 02:45 PM   #11
myfirstyota
3 Yaris and counting..
I have bilstein b8's and tein s-tech's. I daily this combo and im happy with it.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 05-03-2021, 07:59 AM   #12
CrankyOldMan
Brain fart, they're Tokico HTS116. The "red" was all I remembered. Disregard.
Old 05-03-2021, 10:34 AM   #13
Neinris
WOW! I can't seem to find those. looks like I'll be getting Bilstein, it has the name "Tein" in it already anyway.
I rode in my cousin's 370Z, and his suspension is stiff, but still more comfortable than my ride right now with the stock struts. I'm hoping the Bilstein would feel the same as his suspension.
Old 05-03-2021, 05:35 PM   #14
Thirty-Nine
Too bad Tokico doesn't sell shocks in the U.S. anymore. :(
Old 05-07-2021, 08:28 PM   #15
myfirstyota
...I rode in my cousin's 370Z, and his suspension is stiff, but still more comfortable than my ride right now with the stock struts. I'm hoping the Bilstein would feel the same as his suspension.
I'll bet they aren't far off but the only thing I can compare it to was a g35 back in the day..
Old 05-23-2021, 09:44 PM   #16
OzDriver
Drives: Forester XT
Anybody running KYB Excel-G struts/shocks?
OzDriver is offline   Reply With Quote
Old 05-24-2021, 01:56 AM   #17
stidnam
Drives: Starlet
Ozdriver, I wouldn't categorise them as performance, though they'll be about the only option easily available here locally. If you want something performance orientated, order something from the UK. You'll get a full kit for $1k AUD. Alternatively, order something off Yahoo Japan.
stidnam is offline   Reply With Quote
Old 05-24-2021, 02:45 AM   #18
OzDriver
Drives: Forester XT
Ok good tip cheers. There doesn't seem to be a huge selection locally.
Not looking for 'performance' per se, but I would assume they're an upgrade over standard to some degree? When my OE WRX shocks started knocking I swapped to Excel G - car definitely seemed happier with the slightly lower springs I already had.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Recommended After Market Shocks/Struts - Tokico HP & HTS is not available in Country arnoldod Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-14-2013 11:18 AM
Performance? chrisj Off-topic / Other Cars / Everything else Discussions 9 10-16-2010 05:14 AM
>>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< TWM Performance TWM Performance 0 12-24-2009 10:21 AM
Black Friday SALE from TWM Performance! TWM Performance TWM Performance 1 11-27-2009 11:46 AM
