Old 04-25-2021, 08:21 PM   #1
bfe71730
Drives: 2011 Yaris 2dr Hachback
engine swap
my 2011 yaris engine threw a rod 2 days ago, Ive found an 07 as a donor, will this be an easy swap? any wiring differences? Just wanna know what I'm getting into.
bfe71730 is offline   Reply With Quote
Old 04-26-2021, 02:32 AM   #2
remcafee
fairly easy, do yourself a favor and take the hood off it will make it 10 times easier
Old 04-30-2021, 03:30 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Did you figure out why the engine threw a rod? A fairly rare happening on the 1NZ, I would think. In fact, I have been trying to sell my the 1NZ I pulled from my '06. It has 180000 kms on it and runs like new. No one buys these engines as they rarely fail. The cars rot out and get junked with near perfect engines and drivetrains.
The swap should be very easy and no additional wiring would be needed. Just plug the harness connectors back in and it should fire right up. I would remove the wiper tray, radiator and radiator support. This will give you tons of room. You could remove the lower radiator support too and roll the engine straight in. I didn't take the lower rad support off when I swapped in the 2ZR.
2003 Yaris 1.3 engine swap help Jedi4690 DIY / Maintenance / Service 0 03-27-2018 03:08 PM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
