Old 05-23-2021, 09:05 PM   #1
Xwizit1
Drives: 2007 Toyota Yaris 3 door Hatch
Help! My car occasionally electrically dies..
07 3dr 1.5l base model. I upgraded the amp and sub in my car.
I added a kinetik 1900A battery, then I think I destroyed the oem alt. So today I added a Brand X 250A alt. Still has the same problem. The engine bogs down, but still runs, the lights shut off for a second or two, then kick back on.. My first system had a 40A fuse, and this one is 100A.. I also added a train horn, with a relay, to the existing 1 wire.
Any suggestions would be greatly appreciated!!
Thanks in Advance
Xwizit1
Xwizit1 is offline   Reply With Quote
Old 05-24-2021, 10:12 AM   #2
bronsin
bronsin's Avatar
I hate to say this, but it appears the modifications you made to your stereo caused the problem. But unfortunately The cure eludes me.
Old 05-25-2021, 11:45 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Before going any further, you should have at the very least, 3 fuses.
1- close to your front battery.
1- right before your second battery
1- Fused distribution block
Reason is in case you ever wrecked or the power wire touches metal your whole car won't catch fire. Safety first.
I have an 07 Sedan with a kinetik in the trunk on a stock alternator.
Did you do a Big 3 Upgrade ? add a thicker run of wire from alternator to your main battery, thicker ground wire on alternator and a thicker ground on your battery.
Do not remove any of the factory wiring just add to it. A good 4 gauge wire or a cheap 0 gauge will do the job.
Old 05-25-2021, 11:50 PM   #4
_S7V7N_
_S7V7N_'s Avatar
What gauge wire are you running for your system and how big of an amp do you have?
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
