#1 |
![]() Drives: 06 Yaris RS Join Date: Dec 2013
OCS Bypass / SRS Light
I recently purchased a second-hand Occupant Classification Sensor Bypass Module (Rev. 2.0.0). After the installation of the module, the dash airbag light came on.
I tried the DTC code clearing procedure described in this post: https://www.yarisworld.com/forums/sh...d=1#post557473. When I turn the ignition on, the SRS light comes on solid the P/S and ABS light flash at about 5 flashes/second. Any ideas on how to clear the error codes? Vehicle is 2006 RS 2-door hatchback, Canadian. Last edited by LH123; 06-08-2021 at 11:53 PM. |
#2 | |
#3 |
#4 |
Hmm...have you triple-checked that all connections are tight? You moved the seat belt pieces over, too, right?
#5 | |
#6 |
Turns out you were correct. I didn't think that the seat belt connector had to be connected to keep the system happy. When I hooked that up, the fault cleared. Thanks for your help!
#7 |
Yes, the seat belts are part of the overall SRS system. My pleasure, glad you got it sorted :)
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| Do your side windows wipe clear? | CoryM | DIY / Maintenance / Service | 6 | 10-29-2013 11:50 PM |
| P1345 Error code | Nicholas2003 | DIY / Maintenance / Service | 0 | 02-03-2013 06:47 AM |
| Error DTC B1901-B1906 how repair?? | Carlosk1 | DIY / Maintenance / Service | 2 | 08-30-2010 05:15 PM |
| Error DTC B1901-B1906 | Carlosk1 | Central and South America | 0 | 08-29-2010 09:48 PM |
