Old 06-29-2021, 04:32 PM   #1
BarryYaris
Drives: Yaris MK2 Vvt-i 1.33
Exclamation Yaris LED flasher relay problem
Hi, new to this forum after recently purchasing a MK2 Vvt-i 1.33 Yaris.
Decided to swap pretty much all the LED lights with either Osram or Phillips.
All went well until I got to the flashers/indicators. I've got another Toyota so knew straight away about needing to swap out the relay.
The problem is, that despite swapping out the old flasher relay, the lights are still in hyper flash. I thought the relay night be faulty so swapped it with the one from my other car which works perfectly and I still get the same problem.
Has anyone had the same issue and found out the reason for this?
Cheers guys!
BarryYaris is offline   Reply With Quote
flasher, hyper flash, led, mk2, relay
2008 Yaris Sedan Electrical problem VIP Asia 0 01-05-2016 02:49 AM
acceleration problem yaris 2012 sedan ahmedmhb Middle East 1 10-17-2013 05:32 AM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 04:46 AM
