Old 07-01-2021, 07:45 PM   #1
AngryPunk
Drives: 2009 Yaris
Rear brake shoes won't seat properly
Hi. I need some help. 2009 Yaris. Got my rear drums off and rebuilding the brakes. One side went together easily. The other side won't. I think the silver lever that sits behind the shoe that is used for the e-brake is stopping the adjuster from sitting into the shoe properly. That's leaving them too far out and stopping the drum going back on. Trouble is that I can't find a way to reduce the tension on the handbrake cable so that it sits where it should. There doesn't seem to be an adjuster under the car like some vehicles have. Any advice?
AngryPunk is offline   Reply With Quote
Old 07-03-2021, 06:18 PM   #2
AngryPunk
Drives: 2009 Yaris
Figured it out eventually. Driver's side cable seized. That stopped the shoes sitting back properly and so the drum wouldn't go past the shoes. Unseized the cable (undid all the 10mm bolts along its path) then put it all back together. Works perfectly now.
Old 07-05-2021, 03:03 PM   #3
bronsin
bronsin's Avatar
Excellent!
The only way I could get my VW beetle rear drum brakes to work was to disconnect the parking brake hardware entirely.
brakes, e-brake, shoes
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
Broken 40/60 Back / Rear Split Seat Handle / Lever alex_melodymaker DIY / Maintenance / Service 9 10-31-2009 04:55 AM
