Old 06-09-2007, 07:04 PM   #1
hatchbackkid82
Drives: .
NA 1NZ-FE
Hey what's up everyone. Just had a quick question. Does anyone know how much power you can get from the Yaris keeping It NA? I know there isn't much aftermarket out there just yet. You have AEM claiming a solid 5hp from just there CAI. I just a lil skeptical on this. I know that TEIN got 106 Wheel HP and a stock Yaris makes that @ the flywheel. I'm guessing with a real good tune, you could probably get 120 @ the wheel. Anyone know If this is possible, or is anyone making that much yet. Let me know what you think. Thanks
Old 06-09-2007, 07:40 PM   #2
weaponrcamry
Drives: Camry LE/Yaris Hatch 5spd
125 crank hp was the highest Ive ever seen on the 1nz n/a. The key with n/a motors is air flow... Oh this was on a 5speed tranny. Not sure about the auto hp..
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|....,,]
weaponrcamry is offline   Reply With Quote
Old 06-09-2007, 10:11 PM   #3
The key problem with this engine is the electronic management, Toyota made it a pretty tough nut to crack. Once tuners are more familiar with getting piggyback or replacement ECUs to work, we can probabbly see some nice increases... Individual throttle bodies, aggressive cams, better fuel mapping, all those things will come, one day...
Old 06-11-2007, 04:33 PM   #4
Kekropas
Drives: Yaris Ts
something like that.....
http://i62.photobucket.com/albums/h1...itz/moter1.jpg
This was my old Yaris with throttle bodies 38mm, TRD cams, DTA ECU and more things ! 172 hp at 7.800 rpm !!!!
Not bad for a 1.5 litre NA.....
Kekropas is offline   Reply With Quote
Old 06-11-2007, 05:02 PM   #5
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
Nice, got more pics and specs?
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 06-11-2007, 05:03 PM   #6
weaponrcamry
Oh, I thought he was talking about just bolt ons, etc. Did you rebuild the motor "Kekropas". In that case you will have to upgrade the cams, valve train, springs, retainers, built head etc..
Are u talking about rebuilding the motor to get more n/a or just bolt-ons??? "hatchbackkid82"
Old 06-11-2007, 05:31 PM   #7
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Smile swap out the bottem end
the best idea i've seen for NA power is to snag a prius block and use the yaris head. the advantage: the 1nz-fxe (prius) has a higher compression ratio, when compaired to the 1nz-fe...never seen it done, but it is a good idea.
read the details here
http://www.clubxb.com/forums/f28/6433-motor-swap-2/
(here's the good stuff...copy/pasted from the link above)
...I have no doubt that running the 12:1 compression achieved by swapping to the 1NZ-FXE block with the 1NZ-FE head would net closer to 150+ hp to the wheels with a proper tune. And again, the engine management is the most expensive part. The 1NZ-FXE can easily be found for less than $600. The rest of the parts are already on your car. Save for the engine management. The stand alone engine management can be pretty cheap if you do something like Mega Squirt, or up to about $1500-$2000 for a commercial stand alone unit like AEM or Haltech....
fu_im_from_texas is offline   Reply With Quote
Old 06-11-2007, 07:27 PM   #8
hatchbackkid82
Drives: .
Keeping strictly NA, but still streetable. Man 172hp NA is one BADASS yaris
Old 06-12-2007, 01:18 AM   #9
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
some how i doubt a 172hp NA 1.5l yaris would be much fun to commute on the street with...gotta make sacrifices somewhere though i suppose :D
Old 06-18-2007, 07:36 AM   #10
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Kekropas' car rocked!
Very very fast car!There are some videos on Ebay from the Hellenic Yaris Club Trackday, where he tested it.
Old 12-19-2015, 11:34 PM   #11
rabbito
rabbito's Avatar
i heard JUN cams give good 20hp..
E85 flex fuel overboost with ECU tuning gives 20-30hp (upgrade injectors 2zz or 1jz)
i have header, extension-mid pipe and intake..hosnestly i dont think i gained more than 10hp..lol...
Old 12-21-2015, 04:13 AM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
8 years later...
Yes, Jason I believe was able to squeeze around 150ish out of his H Prod yaris.. He uses Jun Cams and AEM EMS. Also a bad ass custom header.
-Derrick-
Old 12-22-2015, 11:36 PM   #13
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
8 years later...
8 y e a r s l a t e r
lol
Sent from my XT1575 using Tapatalk
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 06:39 PM
