Old 07-13-2021, 07:51 PM   #1
Roman
Drives: 2007 3-Door Hatch (US)
2007 Hatch can't shift out of park
I have a 2007 Hatch (US Model)
Can not shift out of park. If the emergency white button near the shifter is pressed, the car shifts out of park fine. The transmission behaves normally. It is purely a matter of the little white knob under the shifter not going down when the brake is pressed, to allow the shifter to mover over to the right, out of park.
No red (warning) lights on the dash, had AutoZone connect a computer and they told me there are no codes. All electronics seem to work fine.
1. Checked fuses. They are good.
2. Replaced brake switch. It was not the issue.
3. Checked and re-plugged in the connector towards the back of the shifter. This guy:
Bad solenoid in the shifter assembly? There is a click every time I press the brake.
Is there anything else to try/rule out? A toyota parts guy told me "maybe a bad neutral safety switch" but from what I have read the car would have problems starting, which it does not.
Thanks for your time friends. Cheers!
Roman is offline   Reply With Quote
Old 07-14-2021, 10:22 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Looks like you're on the right track with the stop switch--that's the only input into the Shift Lock ECU. Can you observe the solenoid when it fires and verify that it's fully retracting the blocking mechanism? It's possible that the click you're hearing is the solenoid firing but bottoming out, or the blocker arm is damaged and doesn't fully retract.
Here's the circuit from the repair manual.
2007 yaris hatch noisey clutch on ac compressor - changed 2007yarishatch DIY / Maintenance / Service 3 06-17-2020 07:12 PM
2007 Yaris hatch - thinking TRD Type-Y General Yaris / Vitz Discussion 18 01-18-2018 11:47 PM
stores water in cowl and wets lower exterior windhield at first driving 2007 hatch dogsridewith DIY / Maintenance / Service 2 07-21-2017 10:32 AM
Just bought 2007 Yaris hatch Lightrfire New YARIS Purchase Forum 5 02-19-2016 04:57 PM
Will not shift into park AlaskaYaris DIY / Maintenance / Service 7 02-19-2013 01:37 AM
