Old 09-08-2021, 07:00 PM   #1
Shibou
Drives: 2016 Yaris Sedan
Fuel gauge shows full but it’s not
Sorry if I’m posting in the wrong section! I have a 2016 Yaris sedan and when I left work tonight my fuel gauge showed I was 3/4 full. When I got home I noticed as I was pulling in the driveway it showed that I was completely full, I have tried a few different things but it’s not going back to normal. Has anyone else ever had this issue?
Shibou is offline   Reply With Quote
Old 09-09-2021, 08:54 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Sounds like the float may be sticking or the fuel level sending sensor is dirty. Or maybe your driveway is really steep? =)
Old 09-09-2021, 11:20 AM   #3
bronsin
bronsin's Avatar
Sounds like taking the fuel pump out of the gas tank and checking the float is in order. Sounds like you’ll have to have a mechanic do that.
But if you can’t afford it just do what us old motorcyclists do. Ignore the gauge and go by mileage. You should be fine driving 200 miles between Phillips
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
2ZR Turbo Yaris 06YarisRS Forced Induction Forum 562 08-28-2025 02:49 AM
Fuel Gauge ab15 DIY / Maintenance / Service 8 07-22-2015 03:42 AM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
Fuel / Temp / Mileage Gauge - Special LED Readings? bigsky2 General Yaris / Vitz Discussion 3 05-31-2006 09:04 AM
