Old 09-28-2021, 04:58 PM   #1
Risto
Drives: Yari 2010 1.3 XP90
Yaris 2010 original LED tail lights
Hi, I have 2010 XP90 yaris and wife is now running without tail lights. It has LED (original) tail lights. Same led acts as running light and brake light. In brake there is 12V and in normal case probably something else? My problem is that without braking there is no voltage to led. Leds are ok but issue is with voltage. I have checked tail fuse and tried to understand relays as well. Probably there is no T-LP relay at all. Also tried to clean and understand light control switch. Still no idea how voltage is generated to LED in normal case (without brake). Is it 6V or something... Do you now if there is some voltage regulator to drop voltage or how it works? Or is it ECU which drives correct voltage to LED? All other lights are fine.
Thank you!
Risto is offline   Reply With Quote
Old 09-29-2021, 05:56 AM   #2
Risto
You should forget that question. I did stupid mistake. I was sure that tail leds are not only for breaks. But they are. Only parking lights are on with head lights...
2010 Yaris - not cranking - dash lights present. jools99 DIY / Maintenance / Service 2 12-10-2016 10:57 AM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
WTB: Leds Tail Lights / sway bar for yaris Sedan ja-cordero Willing to Buy by private party 0 11-12-2010 11:55 AM
RS LED TAIL LIGHTS jimcat Cosmetic Modifications (Exterior/Interior) 11 12-01-2006 11:20 AM
