Old 10-27-2021, 01:04 AM   #1
CrimsonEclipse
Drives: .
Lower Control Arm ball joint bolt seized
Trying to replace the lower control arms on a 2011 Yaris.
The bolt that attaches the control arm to the bearing assembly (locked with a cotter pin (which was removed)) spins without loosening. I placed a jack under the ball joint and added pressure but it wasn't enough.
Can I use a pair of vice grips through the ball joint boot and clamp down long enough to break the threads loose
Note, I am using thread oil to possible loosen up the threads
I am replacing the lower control arms because the rubber around the rear bolt is cracking and possibly failing.
CrimsonEclipse is offline   Reply With Quote
Ball Joint Warning tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-31-2024 08:39 AM
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
2007 hatch front passenger ball joint Phatdonkey78 DIY / Maintenance / Service 4 02-16-2019 11:56 AM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
