Old 10-29-2021, 01:45 PM   #1
Tumbleweed_2
Drives: 2007 Yaris Sedan A/T
Sealing Trunk Lid Rubber Seal
The rubber seal that grips over a metal lip (going around the opening for the trunk) works loose after 18-24 months, resulting in water entering the trunk and causing the tops of things sitting in the trunk to become wet. I have isolated this issue to the rubber seal because I can remove the seal and using a pair of pliers tighten up the 'clenching' strip inside the seal, reinstall the seal and verify there are no more water leaks.
Is there a waterproof, preferably non-hardening(?), sealer or caulk I can apply inside the clenching channel of the rubber seal (before reinstalling the rubber seal) to created a long-term solution ? Thank you for your feedback.
Tumbleweed_2 is offline   Reply With Quote
Trunk Lid Seal Replacement Tumbleweed_2 DIY / Maintenance / Service 1 10-28-2021 07:39 PM
Rubber seal for hood/bonnet artxty General Yaris / Vitz Discussion 3 10-15-2019 01:33 AM
HELP: New passenger side rear light rubber seal needed kavos wildcat DIY / Maintenance / Service 5 12-16-2012 05:38 PM
HELP: New passenger side rear light rubber seal needed kavos wildcat Items for Sale by private party 0 12-16-2012 08:15 AM
Trunk Lid Swap 07typeS Items for Sale by private party 11 09-01-2007 09:32 PM
