Old 11-02-2021, 01:44 PM   #1
Reklaw-79
Drives: Yaris TR
ABS light
So recently bought a 2007 Yaris 1.3 vvti as a run about while I’m between cars, Now the abs light came on last week so I plugged it in and it came up with left rear speed sensor C1333 so after searching online I opted to buy a new rear hub complete with speed sensor however before I went ahead to fit it I plugged the harness into the new hub cleared the fault and spun the hub up while holding it and the abs fault came back abs light on the dash with the same C1333 left rear, my question is would the hub need to fitted to the car and driven to calibrate the new sensor?
Many thanks
Reklaw-79 is offline   Reply With Quote
Old 11-02-2021, 02:59 PM   #2
The problem is usually corrosion buildup on the wired sensor the connects to the hub, not an issue with the hub. Do some searching here. There are many instances where people have had success cleaning the sensor and applying liberal amounts of dielectric grease before reconnecting.
Old 11-02-2021, 03:09 PM   #3
Reklaw-79
Drives: Yaris TR
When you say clean the sensor do you mean the harness plug and sensor plug?
Old 11-02-2021, 03:16 PM   #4
Clean everything making the connection, both hub side and harness side.
Old 11-02-2021, 03:18 PM   #5
Reklaw-79
Drives: Yaris TR
Thanks I’ll give it a go, so it can’t be the hub at fault if the new one still brings up the fault code
Old 11-02-2021, 05:03 PM   #6
Reklaw-79
Drives: Yaris TR
I was tempted to swap harnesses left to right to see if the fault occurs on the other side
Old 11-03-2021, 12:01 PM   #7
bronsin
bronsin's Avatar
good idea!
I swapped MAF sensor’s between my Yaris and my sons echo. Then the Yaris had a code and the code on the echo cleared
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
Toyota Yaris 2002 ABS and ! Light Rihsky DIY / Maintenance / Service 3 12-01-2015 09:16 AM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
Brake & ABS Light On JeffRapp DIY / Maintenance / Service 3 01-04-2013 11:10 PM
Toyota Yaris -06 VCC and ABS light went on? goedafred DIY / Maintenance / Service 4 03-01-2011 12:22 AM
