Old 11-09-2021, 02:17 PM   #1
Pinchlite
Drives: 2007 yaris HB
crack wheel well drivers side rear...
It looks wet because I sprayed with some rust inhibitor.
Its very solid and no flaking or anything like that.
Its a seam that appears to have opened up..
Pinchlite is offline   Reply With Quote
Old 01-27-2022, 09:27 AM   #2
IndestructibleYaris
Probably just the rubber shrinking. I wouldn't worry about it unless you can see inside the car through it
IndestructibleYaris is offline   Reply With Quote
Old 01-27-2022, 09:39 AM   #3
Pinchlite
Cant see through it..
not too concerned ...I was just curious if its common?
Thanks
Old 01-30-2022, 03:19 PM   #4
sh0rtlife
i dunno if its common to the yaris but its common to alot of cars, most guys just never notice, "if" your concerned about it, chip out as much as you can and re-coat the area with seam sealer
Rust - Sill and rear wheel well jansen.fan DIY / Maintenance / Service 20 01-07-2019 10:54 AM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
