Old 06-11-2007, 11:00 AM   #1
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Did I read somewhere
I remember reading, Somewhere in this Forum, that a Scion TC Throttle Body would fit our 1NZ-FE Engines...
Does anyone know if it's true?
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 06-11-2007, 01:33 PM   #2
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
most toyota throttle body's have the same bolt pattern and use the same connector. the problem is that the ecm will not accept some. i'll be putting a 1zz tb on a yaris soon and port the intake manifold. i wouldn't do that big of throttle body unless you were FI
Toyotech is offline   Reply With Quote
Old 06-11-2007, 02:29 PM   #3
joey1320
joey1320's Avatar
Drives: Yaris LB
ask turboyaris he just made a new intake mani and used the tc tb. he may know if its a direct swap.
Old 06-11-2007, 05:59 PM   #4
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
anyone else doing these intake mods and having no luck? anytime the man. pressure, pipe dia., maf sensor location changes it throws codes or stalls out.
mikeukrainetz is offline   Reply With Quote
Old 06-11-2007, 08:32 PM   #5
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
the bolt pattern is the same, the connection and all is the same, the vacuum fittings are slightly different but i believe all you should need is one or two caps. As far as working, it seemed to work on my vehicle, i have yet to be able to say for sure as i have done nothing more then idle with it and verify that pressing the throttle opens the butterfly. It may be difficult though to properly port a stock plastic manifold however. as i mentioned before i would give it probably another week before i can say for sure how it all works.
turboyaris is offline   Reply With Quote
Old 06-11-2007, 10:44 PM   #6
Toyotech
keep the maf diameter the same as stock or as close as possible and the maf frequency shouldn't throw a code. for the throttle body, theres a bunch of codes that could be thrown being that theres dual resistors...one for high side, one for low side. most throttle body's will get a signal from the throttle pedal position switch but due to slight differences it will throw a code after about 37% throttle
Old 06-12-2007, 02:37 PM   #7
mikeukrainetz
can you add a resistor to the MAF sensor to compensate for dia difference? maybe a dumb question but if your going through all the trouble to port heads, build manifolds and add larger dia throttle bodies doesnt it make sense to up the available volume of air being able to pass through the intake? whats the stock dia intake rated in CFM?
1/3 throttle is when my car stumbled and wouldnt pick back up and stalled out.
Old 06-12-2007, 03:17 PM   #8
Toyotech
im on top of that, with future tuning software available you would be able to run such items like a tacoma maf where you would be able to play with the variables. theres a lot to be done but for a n/a monster....hehe yaris i would like to see about a 60mm throttle body, 2.50"-2.75" piping and matching maf.
the toyota's eprom will compensate the difference so theres going to have to be a different way with the resistor. no idea what the rating is...
Old 06-13-2007, 02:09 PM   #9
YarisGuy
Drives: 2006 Yaris
Originally Posted by Toyotech View Post
theres a lot to be done but for a n/a monster....hehe yaris i would like to see about a 60mm throttle body, 2.50"-2.75" piping and matching maf...
That would be pretty crazy!
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 06-13-2007, 02:47 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
TOYOTECH,keep us posted on the1zz tb. i happen to have one in my hands as i type this....
Old 06-13-2007, 03:05 PM   #11
Nutzoids
Nutzoids's Avatar
This is Awesome info... Thanks everyone, keep the Info flowing. It might not be in my hand, but getting one would be quite simple for me.
Looking forward to seeing how this turns out!
Old 06-13-2007, 03:29 PM   #12
Toyotech
very easy to get...its just the pricing. most 2az throttle body's are expensive because of all 02-04 dbw throttle closed or open issues. but you could find a 1zz throttle body for about 25-50 bucks
New Buyer Beware-WARNING-MUST READ THIS drdavidr4u New YARIS Purchase Forum 25 07-28-2007 12:17 PM
JUST READ THIS... forpinks Performance Modifications 15 02-21-2007 08:29 PM
