Old 12-11-2021, 01:25 PM   #1
jimmmmmy
Oil pan change on 2009 1.0 VVT 1KR-FE
Hi,
I was wondering if anyone has any experience of changing one of these?
I have a small crack in mine and have bought a replacement, I tried to replace today and got stuck.
I can't get a ratchet to attach to either of these 2 bolts, not sure if this is because the fly wheel partially obstructs or I need a different ratchet set.
Does anyone know if these can be accessed with a special tool? Surely you would not have to remove the flywheel .
Hopefully just me being dim.
Thanks for any help.
jimmmmmy is offline   Reply With Quote
Old 12-12-2021, 09:47 PM   #2
remcafee
there should be a plastic cover covering the little opening to the flywheel gears and stuff exposing, should get a wobbly socket to fit in there
Old 12-13-2021, 01:57 PM   #3
jimmmmmy
Hi,
Thanks for the reply. I tried for ages with my 1/4" ratchet set, I could see them but couldn't get an angle to get the socket over the bolt/nuts, even with the universal joint attachment.
In the end I just cleaned up the crack and stuck a load of epoxy over it.
Once this fails I will try again, even if I manage to get them off with a thinner set I can see it being impossible to get them back on.
It is good to know that it can be done though.
Thanks.
2ZR Turbo Yaris 06YarisRS Forced Induction Forum 562 08-28-2025 02:49 AM
Oil Pan Drop 06YarisRS DIY / Maintenance / Service 17 12-14-2017 09:11 PM
? Drop oil pan to check pump pickup screen Toyota Yaris 1NZFE dogsridewith DIY / Maintenance / Service 13 10-23-2017 06:45 PM
Help with oil change trevor1980 DIY / Maintenance / Service 3 02-05-2012 10:46 PM
