Old 12-11-2021, 08:51 PM   #1
OTOC
Drives: Toyota
2017 iA window stuck
My '17 Yaris iA is having a problem with the back passenger window. It will roll down but not up. I tested (with a voltage meter) voltage at the plug and get 12v on the grey wire and brown wire. The window motor I have will spin both directions. I used jumper wires between the plug and motor. The grey wire has voltage both up & down direction. The brown wire only has voltage going up. I tested continuity from the up/down switch plug to the window motor plug. Both wires tested good. The switch itself also tested good for continuity when checking for proper direction of flow.
Some I know suggested that I test the driver switch for everything too. I'm asking you all if there is anything else I should be checking?
Thanks.
OTOC is offline   Reply With Quote
DIY - OEM Power Window Conversion CTScott DIY / Maintenance / Service 29 10-27-2024 11:02 PM
Passenger Power Window replacement AMOKS DIY / Maintenance / Service 0 03-15-2016 09:29 PM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
Electronic Window Closer mod cali yaris In Car Entertainment + Electronics (audio / video / alarm) 8 11-11-2011 11:16 AM
Window won't work after changing speakers Grantstead DIY / Maintenance / Service 0 07-16-2011 12:57 PM
