Old 01-01-2022, 06:09 PM   #1
YOUNG SCOOTER
Drives: 2008 Toyota Yaris Hatch
replacing radiator, 2 small hose fittings on bottom of new radiator
I have 2008 yaris manual transmission. I hit a block of ice today and now coolant is coming out of the front end. I got a new radiator and it has the upper and lower hose connections, and it also has 2 brass fittings on the bottom that stick out towards the engine. I dont see those on my existing car. I am assuming those are for a transmission cooler for an automatic? I have a manual. Can I just cap off those fittings? I would assume those are also a separate "passageway" than the coolant, designed for the ATF fluid to flow through the radiator in its own channels. So technically you can leave them completely open. Correct?
YOUNG SCOOTER is offline   Reply With Quote
Old 01-02-2022, 01:23 AM   #2
Turbiini
Drives: 1983 carina 2NZ-FTE
yes
Turbiini is offline   Reply With Quote
Need advise (Radiator Hose/ Thermostat Gasket) vellano DIY / Maintenance / Service 7 12-12-2012 11:37 PM
Silicone radiator hose VA_yaris General Yaris / Vitz Discussion 18 07-31-2011 04:13 PM
Radiator hose size window_lee General Yaris / Vitz Discussion 0 03-31-2009 06:33 AM
Radiator Hose Question Treyz General Yaris / Vitz Discussion 6 11-16-2008 06:56 PM
