#1 |
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
ABS light on randomly
Model 2011 yaris sedan.
ABS light comes on randomly after some distance of driving and the wheel turns hot. The light will eventually come off after stopping for a few moments and the wheel temperature get colder. Or clear the code using OBD2 scanner. Pull the code and get DTC C1402 "Malfunction in Front Speed Sensor LH Circuit". Already tried to clean both ABS sensor tip and ring sensor, but error is still on and off. Does this mean i have bad ABS sensor? |
![]() Drives: Toyota Yaris 2007 hatchbac 1.3 Join Date: Jan 2022
I have the same issue I already changed the bearing for a genuine one, I’ve already changed the speed sensor and the code still showing so abs light and the traction control light still on even when I cleared the codes many times, I don’t know what else to do.
#3 |
![]() ![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Look carefully for a cracked tone ring.
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| parking brake light on & abs light on ! car stuck in 2nd gear !!! | Bony_ahmed | DIY / Maintenance / Service | 3 | 04-29-2019 06:57 AM |
| Yaris 2007 ABS & Brake light issue after wheel bearing change | DevilzMafia | DIY / Maintenance / Service | 4 | 01-17-2013 09:24 PM |
| Brake & ABS Light On | JeffRapp | DIY / Maintenance / Service | 3 | 01-04-2013 11:10 PM |
| Sharing and Need Help! Lowered but abs light came on! | tobymak21 | California | 0 | 08-08-2012 08:48 PM |
